Woodstock Ontario Fire Frequencies
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Has Woodstock moved over to a trunking system? I wasn't aware of that.
There are lots of conventional frequencies in the database for Woodstock fire.
JohnnyCanuck
Woodstock
Oxford Regional Fire is still non-trunked but Woodstock City is now off that system and currently is 'silent' so am assuming they are now trunked.
JohnnyCanuck
Woodstock
One further comment on the Woodstock Fire Department Radio System. I used to regularly hear 'dispatch' check all units - mobile as well as portables - once if not twice a day. Also I used to regularly hear the fire calls and internal communications on scene. All that is now totally silent so assume they are trunking but have not found on what frequencies.
Forts
Ontario, Canada
I might be down that way early to mid next week. If no info has turned up by then I'll bring my gear along and see what I can turn up.
JohnnyCanuck
Woodstock
Thanks very much 'Forts', I appreciate that. In the meantime I am going to continue searching to see if I can determine anything. If I do I will post the results.
ve3tej
London, Ontario
City of Woodstock Fire Dept are on 158.385, this is the output of the repeater
JohnnyCanuck
Woodstock
Many thanks ve3tej. I will park on 158.385 for a while and see what comes up. All things being equal, there should be a department radio check about 8:00-9:00am tomorrow morning.
JohnnyCanuck
Woodstock
Much obliged ve3tej! I caught the WFD radio checks at 8:10 am today on 158.385. They have indeed moved from the site I was picking them up on previously (approximately 3 years ago). BTW, I note from your avatar you may have frequented the same TH's for 'double-doubles' that a friend of mine did - looks like the same 'cruisers'! Thanks again!
