fordman2006
I have a Workman t734 antenna in a tower on my roof and a couple of times a year I find the a piece of the antenna on the ground after a big windstorm. I have to get the antenna down and screw it back in, I make sure it's in the base far enough and turn the nut tight but it comes loose again after a while. Cab I use loctite or will that stop the piece from grounding to the antenna? Or is there anything else I can use so they won't fall out?
