World leaders and celebrities in (where else than) Pebble Beach on Sunday
scankid2591
Salinas, CA
This coming Sunday Tony Blair, Bono, Bill Clinton, Al Gore, John McCain, and the Governator are all gonna be in Pebble Beach.
If only I had a digital-enabled scanner. :roll:
Secret Service (and probably Diplomat Protection) are gonna be on scene watching the whole thing go down.
hardware1197
San Francisco
Monitor for CAPS!
It's kinda of fun to listen to your local ATC centers when big wigs are in town. Since Yesterday two ANG F-16's have been flying Combat Air Patrols over PM Blair wherever he goes, taking a TFR (Temp Flight Restriction) area with them. You'll hear callsigns "Gasket", and "Jumper", in CA.
Today Oakland center says stuff like,
"American 1187 clear direct MOXEY, caution traffic at 10000 feet, two F-16's heading 090."
My favorite was a couple of months ago when GW was in town, an older Piper pilot who said, "Restricted? I fly this way all the time and it is not restricted."
The response from the center was, "Sir, I stongly encourage you to turn to heading 040."
Then Gasket 44 came up on the air, "What is the heading of that aircraft, Oakland Center?"
The old man stated, "Oh now I get it, 0-4-0!"
I wish I had recorded it!
If you have a good mil air band scanner and antenna, you can also try searching for the air to air comms for the ANG. If someone grabs the freq post it up! These guys get pretty bored turning rectangles at 10000 feet for 4 hours, then refueiling to do it for 4 more. They tend to chat it up about you name it....it can be funny.
scankid2591
Salinas, CA
Hmm... Well, I did hear a radio test this morning (actually just 10 minutes ago @ 0800) on 147.1500 had a PL of maybe 167.9? (the scanner flashes it and I only saw it for literally half a second). I caught the tail end of it, but it said "____ Repeater Test. 8:00." There's some guys talking about water on 147.1800, 110.9 PL.
What should I search for on the quick search for? Maybe 160-170 MHz with a 5 kHz step, Modulation turned to NFM?
If I get any of those I'll post them.
b52hbuff
I just pasted the custom search ranges from my .usc file below. Scankid, you can open up your .usc file and paste these in.
F-16's seem to chat in the 138-144/AM and 148.0-150.8/AM bands.
I have also pasted a snippet from my .usd file for the 144th, enjoy
Custom Search Range
CustomSearch,1,MilAirVHF1,01380000,01440000,1250,AM,OFF,2,OFF,LOCKOUT,2,OFF,AUTO,8
CustomSearch,2,MilAirVHF2,01480000,01508000,1250,AM,OFF,2,OFF,LOCKOUT,2,OFF,AUTO,8
CustomSearch,3,MilAirUHF1,02250000,02890000,2500,AM,OFF,2,OFF,LOCKOUT,2,OFF,AUTO,8
CustomSearch,4,MilAirUHF2,02890000,03430000,2500,AM,OFF,2,OFF,LOCKOUT,2,OFF,AUTO,8
CustomSearch,5,MilAirUHF3,03430000,04000000,2500,AM,OFF,2,OFF,LOCKOUT,2,OFF,AUTO,8
CustomSearch,6,MilGndVHF1,01380000,01440000,1250,FM,OFF,2,OFF,LOCKOUT,2,OFF,AUTO,8
CustomSearch,7,MilGnd162,01620250,01740000,1250,AUTO,OFF,2,OFF,LOCKOUT,2,OFF,AUTO,0
CustomSearch,8,"400MHz/Gov Trunk",04060000,04199875,0,AUTO,OFF,2,OFF,LOCKOUT,2,ON,AUTO,8
CustomSearch,9,"800MHz Trunk",08510000,08689875,0,AUTO,OFF,2,OFF,LOCKOUT,2,ON,AUTO,8
CustomSearch,0,"900MHz Trunk",09350000,09400000,0,AUTO,OFF,2,OFF,LOCKOUT,2,ON,AUTO,8
144th Frequencies
Channel,FAT/Tower,01182000,,AM,NONE,OFF,UNLOCKED,OFF,OFF,OFF,AUTO
Channel,"FAT/144th Ops",01381500,,AM,NONE,OFF,UNLOCKED,OFF,OFF,OFF,AUTO
Channel,"FAT/144th A-A",01382250,,AM,NONE,OFF,UNLOCKED,OFF,OFF,OFF,AUTO
Channel,"FAT/144th A-A",01384000,,AM,NONE,OFF,UNLOCKED,OFF,OFF,OFF,AUTO
Channel,144thAA,01383750,,AM,NONE,OFF,UNLOCKED,OFF,OFF,OFF,AUTO
Channel,144thAA,01436250,,AM,NONE,OFF,UNLOCKED,OFF,OFF,OFF,AUTO
hardware1197
San Francisco
Air to Air chats
Make sure you are monitoring 121.500 AM.
Any time I've picked them up they've been in the military UHF AM band. I recall 357.0 Mhz as being one. I see you have the 144th there....good start. I'll bet they have air to air chats in the UHF range too. In addition, I'm not sure who'd be refueling them, but typically whetever the normal refuleing corridors are in that area would be used, with the same freqs.
Here's a site which will give you and idea where to start. Nothing for CA, but AZ is mentioned:
http://www.milaircomms.com/uhf_cap.html
Good luck! I'm in San Fran, so probably too far to do anything.
edit: I found the refuel track for off the coast: AR634 and Track 6 which shows ops freqs of:
235.1000 AM
319.5000 AM
352.6000 AM
Here's the corridor map:
http://www.milaircomms.com/images/refuel_tracks_large.jpg
scankid2591
Salinas, CA
Okay...
Here we go.
I was monitoring stuff from 11:45 til about 20 minutes from 13:00 today.
Then I was monitoring some more from 15:45 till about 10 minutes ago.
Here's what I heard:
170.0625: P25 transmissions - 11:45 AM
167.6625: P25 transmissions - 11:49 AM
USSS CH: Charlie: sounded like static. - 11:53 AM
141.9000: Sounds like static: 11:55 AM
366.4500: Tail end of a transmissions: 11:56 AM
167.7875: P25 Transmissions: 12:15 PM
143.9000: *Man with a British accent talking*: 12:19 PM
170.4625: P25 Transmissions: 12:21 PM
360.4500: Static?: 12:22 PM
358.8000: " : "
358.1750: " : "
352.0000: " : 12:24 PM
155.7000: P25 Transimssions: 12:29 PM
169.6375: " " : "
171.1000: This didn't sound like static or a P25 transmission. Tiny bursts of a beep every 2, 5, 10, 15, 20, 30, 45, and 65 seconds. *Not in that order though.*: 12:31+
288.8000: Static?: 12:36 PM
141.3750: Tail end of a transmission: 12:37 PM
148.1500: Repeater tests from "Salinas Repeater" to "Palo Alto Base": 3:45 PM
267.3750: Possibly MilAir... Very, very scratchy.: 3:49 PM
172.0000: Tail end of a transmission: 4:14 PM
236.0000: Static?: 4:15 PM
I'll monitor some more tomorrow.
cristisphoto
Dat bursts..
scankid2591 said:
Okay...
Thats probaly data...
Data being sent to whatever ,MDT CAD etc....
Crista
scankid2591
Salinas, CA
Does someone know who 148.1500 is?
They were doing "repeater tests" from "Salinas repeater" to "Palo Alto base".
Anyone know whos chatting?
Kirk
DB Admin
I'd be willing to wager it's the Civil Air Patrol, which has nothing to do with the dignitary stuff you were trying to catch.
scankid2591
Salinas, CA
Hmm... I wonder what CAP was doing around here...
Also, I just heard a P25 transmission on 167.7875. If I'm not mistaken that's a Homeland Security freq.
I wonder who's here. :confused:
cristisphoto
Most likely a cary for a Federal law enforcment"
In other words
Yes probaly SS :wink:
Crista
scankid2591
Salinas, CA
I saw a black (Bell) 212 fly over Salinas yesterday... :)
Ahhhnold is gonna be @ Salinas High on Tuesday. I'm gonna be there... HELLLO CLOSECALL. :D
Mick
Western U.S.
Ahnold
Everytime he's in SoCal his security team uses 460.375S 127.3; also 460.45S has been reported in use.
