yessssssss al the way.With upgrade would it be worth purchasing in 2020 if I live near simulcast? I can’t get it for $100 . Thanks
Update ezscan, then the cpu firmware, update the library and all your programming. Enable all sites until you find which ones the scanner receives best, you can do this by adding a wildcard to each of the talk groups and set it to record, then you can go look at the recordings in ezscan and see which sites it receives the most recordings, then lock out the rest.@Peerlessk
I did the upgrade from whistler when they first came out with the update. And today I decide to fireup the old radio been years I used it. There is a new p25 phase ll system and it doesn't do well with simulcast.
P25p2 it's alright I can use it for something else for uhf dmr stuff.For simulcast P25? No, just NO.
