Those are used for spying on neighbors.
They have fairly thick wires coming out, thicker than a normal coaxial cable.
There is some radio interference in the area. How would they spy on neighbors?
No, there is no grounding rod that would allow for this to be used in the way you say, I am going to rule out this theory Mr. McKenna. Cables lead to the interior. Also, their are tiny radomes on the antennas. Radomes are typically used to cover a transmitters or receiver to protect from ice, wind noise, or to hide the direction in which the device inside is pointed. Addionally, Radomes are used primarily for transmitters/ receivers operating in the microwave range such as radar or other. If you look in the pic, you will see the antennas have tripods which are attached through the roof shingles. They appear to belong on a watercraft vehicle, but are on the house. Their are a total of 5.Do those thick wires run down the building and then into the ground?
mmckenna is right. It's for surveillance. It works quite well and RadomeRR, you're almost out of milk.
Did you click on the link I gave you in post #2 ? Here it is again, just click on the blue text below:
