Hello all,
This is my first post to this forum.
I am also running into this problem.
First the technical details:
Computer: MacOS Sierra ver 10.12.6
Radio: KG-UV8D (new-received it this morning)
Problem content and observations:
When dumping from Chirp to the radio the R-DCS code defaults to D-77I (that's an i)//D-77i(but capital letter i)
I can go into each station on the radio and manually change it, but for me that is over 200 channels.
Interesting bit of information of which I hope is useful: When I change the R-DCS code to off on the radio and then import back to Chirp, whatever channel I change, imports back to Chirp as an error. As a side note when I export from Chirp to a CSV file (Comma Separated Value) and open it to excel I do not see a column that will designate a setting for the R-DCS setting. If I were a betting man, and I am (sometimes) I would say Chirp needs to add a value/field for this setting as the export process does not default correctly..
Please let me know if I can help and let us know if there have been any modification as Chirp is also my preferred point of data entry.
--Scott
--Scott
