Wouxun KG-1000M MURS Base/Mobile Two Way Radio
iMONITOR
Silent Key
S.E. Michigan
had no idea this existed. At first I though what a great idea, I should get one for the house and the SUV. It has a ton of features and good reviews. However like all MURS radios range (1-2 miles) is severely limited to make it really practical and useful. Why do I still want one?
I
That's a LOT of money for what is essentially a hobbled radio.
But, a good LEGAL option for those that want to run base or mobile MURS.
The big advantage I see is the ability to run an external antenna. Getting a quarter wave antenna on top of the vehicle would really let MURS do its thing. Same for base use, a good antenna and 2 watts would be a good license free/license by rule alternative for many.
iMONITOR
Silent Key
S.E. Michigan
Realistically, with a good hi-gain base antenna mounted about 30 feet off the ground and a good NMO mounted antenna in the center of the roof of my SUV, what kind of range could I expect in the typical suburban area with no tall obstructions?
FKimble
Newnan, GA
Pick up a used VHF Kenwood for less! More power. Probably much better radio. Can also be used for 2m ham and NOAA weather.
Frank
KevinC
Other
Super Moderator
Home
If you're referring to 95.367, there are no type accepted MURS radios with selectable power levels available of more than 2W. Not really sure MURS would be the smartest choice in an emergency either.
It was a joke. If I have to say that then I failed. ☹️
