N9PTC
I'm brand new here, just registered a couple hours ago. I've been searching the forums on this subject. Most of what I've found I already knew. I'm not a ham but will take a day long class and test afterwards on August 11th. I am licensed GMRS user and have used Kenwood Commercial radio's, mostly TK-390, for several years.
I recently purchase a couple dual band radios. One is a Baofeng UV-5R, I like it except that it does not have a channel selector knob on top of the radio. So then I purchased a Wouxun KG-UV2D which so far I find to be fantastic. However I see a newer KG-UV6D that some of the models are touted as Public Safety grade, similar to my Kenwood TK-390, which has caught my interest.
However the more I read, the more I think my KG-UV2D is a better overall radio than the UV6D. The only thing I see the UV6D does that my UV2D doesn't is that it has 199 channels, which I don't think I'll ever come close to needing. I understand that you have to order in the UV6D either the UHF 400-470 MHz or 420-520 MHz and that you cannot then change it with after market software if you later find you'd rather have the other version.
For my UV2D I've found the aftermarket software that lets me program the radio to either 400-470 MHz or 420-520 MHz which I have done that latter. Also the only other feature the UV6D has that I liked was the 2.5 KHz step. However I've found programming software that allows me to program my UV2D to have the 2.5 KHz step, so that is no longer an advantage.
So what other advantage does the KG-UV6D have over a UV2D, which is less expensive and can be found at times used at even less cost (I got mine for $75 shipped)?
