Wouxun KG-UV6D "Frequency Mode"?
KF5ODK
Fort Worth, TX
Manual says "Menu" -> "S/D" puts you into frequency mode. I enter that sequence and get the six dashes for frequency input. I input a valid frequency (example: 4 4 4 0 0 0) and it immediately goes back to the previous channel I was on. How can I input a frequency so I can program a channel by hand????
TIA,
Bob
Sent from my GT-P7310 using Tapatalk
thomast77
Santa Rosa County, Florida
TIA,
Bob
If I am correct it would be the same as the KGUV2D. Try menu+2+1+menu and change it to FREQ mode with the up/down arrow keys. Then press menu again then exit. That will put you in freq mode so you can program memories manually.
Edited to add: Here is a youtube video that should help with manual programming.
Thunderknight
Bletchley Park
Not sure if the 6D is the same as the 6X that Powerwerx lists, but the 6X is being sold as more of a commecial radio and the instruction sheet that I saw included in a 6 (not sure if it was D or X) (and the sheet was seperate from the book) said that you had to enable the menus in the programming software to get frequency edit.
I don't have one here to try that, but if you have the software and cable, check the options for something like "Menu Enable".
The Powerwerx website says they come keyboard locked to meet FCC regulations.
Wouxun KG-UV6X Dual Band VHF/UHF 200 Channel Handheld Commercial Radio [KG-UV6X] - $174.99
VA3JO
Re: http://www.youtube.com Video
The Video at Wouxun KG-UVD1P Programming Guide *ENGLISH* UV2D UV3D - YouTube is actually very good. The manual is in places grammatically quite poor. If you've been around and have had other recent up-to-date equipment, you'll be fine just pressing buttons and getting it right. But if not, this video will get you where you need to go!
My problem was quite simple: To make some settings (for example to select Power Settings), you need to Get Out of the Channel Setting, and Move into the Frequency Setting. From the Video: Simply Press Menu followed by TDR. To go back to Channel Setting, Same Thing! Menu - TDR :)
KF5ODK
Fort Worth, TX
The 6D is much different than the earlier models. Yes the manual is very poor. And I have enabled menus in the software. What the manual says will enable freq mode does not work.
KF5ODK
Fort Worth, TX
Ok I'm an idiot. My interpretation of the manual had me attempting to enter a frequency when it was actually asking me for a password. If you have a "mode password" set (which was 121212 out of the box) it will display six dashes "-" when you do Menu -> 2 -> 2 -> Menu. I thought it was asking for a frequency... Once I got my head wrapped around that I was able to enter frequency mode. I also found in the manual that if you set the "mode password" to 000000 (via the software) it will not prompt for a password...
