Hello all, I am trying to connect a Wouxun KG UV6D radio to a Rugged Radio, 2 way headset. I bought the Kenwood compatible cable. When I connect the cable to the radio, then connect the headset, the radio transmit light comes on, the radio keys up (there is no audio transmitted). I can not get the radio to unkey while it is connected, nor will it transmit audio while it is keyed up and connected. The Push to Talk button is on the headsets and is not pushed.
The info I can find, says the radio uses the Kenwood K1 connector cable (and Kenwood speakermic), the cable is marked as being for Kenwood. I sent back the first cables and bought another model of cable thinking perhaps they were advertised wrongly. The replacement acts the same way. (shipping is killing me by now)
The radio is the version with the SMA Male connector on the radio (for the antenna). It appears there are different versions available.
Am I doing something wrong or is there a radio setting for using the speakermic?
Is there another cable that I should be using instead of the Kenwood K1 connection?
Thanks in advance for any help !
Carl
Carl
