Wouxun Wouxun KG-UV9D Mate will not go to channel mode
cdservices2011
I recently purchased this radio and havew it programmed with Chirp. However I am unable to access channel mode on the radio. When long pressing the TDR/VM button as described nothing happens. Radio stays in frequency mode. I can't seem to find a setting related to it. Any help is appreciated. Thanks
cdservices2011
For the benefit of others; I finally received a reply from Wouxun. They suggested holding the "2" key while turning it on. Make sure it says "mode 2" This corrected my problem. No explanation as to what may have caused it however. Thanks
medicrfg
This is caused by doing a factory reset on the unit. I had the same issue. I have also been advised to hold down the number "2" key and turn on the radio. My radio goes through it's start up, I receive the "model2" message, and I can switch to channel mode. My new problem is I only have 2 channels available (001 and 002) in channel mode. I also cannot upload channels using the software that came with my radio. I keep receiving the message that "channel xxx is out of frequency range" and these channels come directly from RadioReference and RepeaterBook.
rescuecomm
Travelers Rest, SC
The Baofeng UV-9D is a an amateur (ham) radio and is shipped with the transmit frequency range limited. You are getting that error because some of your your programmed transmit frequencies are outside of those limits.
