Wouxun KG-UV9D Plus Help Needed!
N1SQB
Somewhere On Earth
What about the configuration settings tab and VFO settings tab?
Here ya go!
Configuration setings are just menus for the different functions.
VFO tab just shows you what is on the different VFOs!
bharvey2
Things are a bit confusing. Maybe it has something to do with the scanning. That is the only place that I can see any type of frequency limits that the operator can control. Maybe, as a test, try the same codeplug but with none of the channels in a scan group. Other than that, maybe you can widen the scan range. I'm not seeing any errors that stand out.
N1SQB
Somewhere On Earth
Yeah that's what has been bugging me all along. I have Motorola trunking software that doesn't give me this much grief!
Manny
N1SQB
Somewhere On Earth
I finally cracked it!
And I don't mean my head either! ;) So here is what I discovered:
In the VFO settings there is a setting " Current Mode Set"."work CH A B Under each of the A B settings, you have to set a memory channel. That, I discovered, goes hand in hand with whatever you have programmed on your main memory channels. So you can use the drop down arrow to choose any wide band channel to act as your working channel in -A but in B setting you have to choose the NEXT channel programmed that fits in the 100-400 mhz range. That is because working CH has to be interpreted as VFO. The default from the factory is A-CH-1 and B-CH-2
So I just left ch-1 on VFO-A and just chose the very first memory channel after that which had a 100/400 mhz frequency. BINGO! problem solved!
Manny
bharvey2
Well, I'm glad you figured it out. I'll have to say that isn't something I would have suspected. I thought that the working mode was for the channels that the radio would default to as it boots up.
N1SQB
Somewhere On Earth
For a while I thought the same thing. But I was determined to try anything and everything to figure this out. I had nothing to lose at that point. I had already saved a good copy of the plug so no matter what I tried, I could always reprogram the radio. I'm telling you, if it wasn't because I really like this radio, I would have just sent it back. However, this thing is awesome on aircraft and really good everywhere else. That is why I tried so hard to figure this out. Well, that and the fact that it was getting under my skin not knowing! LOL...;)
Manny
Anderegg
Enter text in this field
San Diego
I just got my UV9D Plus from AmazonaChina..........new look apparently, it has a dotted speaker grill, and has the same shape as the non Plus version. The box looked like a regular 9D box, but has an "Upgrade" sticker, same for the manual. Odd, but since it came direct from China, it must be the newer version?
Paul
NC7BD
Hiddenite, NC
Programming Help
I too am having difficulty programming the radio. I need to enter some MURS frequencies and they will not transmit, only receive. I wish someone could do a comprehensive guide like miklor did for the Baofeng UV82
Does anyone know if the radio comes locked by default from transmitting outside Amateur bands?
pr5012
I know with some of the Wouxun products, different vendors have different versions with varying band splits. I bought one from a vendor with a tighter than advertised split. I had to find a program on the web that would allow me to adjust the split.
I believe I have just purchased one of these radios that's locked into a tighter than advertised split, bharvey2 or anyone else know where to find a program like this to adjust the split?
gewecke
Banned
Illinois
Hopefully its amateur bands only. 73, n9zas
G3NHS
England
Woke up this morning and tried to add different channels to the radio. THIS is what I got! You guys take a look and see if you see anything I'm doing wrong!
Just cracked this one based on comments on here and experimentation.
The problem is on the VFO Settings tab. This defaults to CH-001 and CH-002 and expects to see the required Tx/Rx range in these. I wanted to set up a data file for airband but as the CH-001 and CH-002 frequencies that I was trying to program were out of band for the Work CH, I set up channels CH-998 and CH-999 with one freq on 2m and the other on 70cm and then set the Work CH to point to these channels.
Note that you need to populate the channels before you select them or they will revert to 001 and 002.
After doing this, all of my saved freqs correctly uploaded to the radio.
Next thing I need to find out whether it's possible to convert a CSV to Wouxun without CHIRP or an expensive alternative...
Jon
tpruszin
Jon
Hey did you manage to find an easy way to get a config on a 9D CHIRP still doesnt support this radio
