Wouxun Wouxun KG-UV9D Plus: Only two channels showing?
KM6VWP
Hi, I just purchased a wouxun KG-UV9D Plus to use as a dedicated HT for sat work. I'm using the RT Systems programming software, and while I can upload and download my frequencies (all 70cm and 2m) to the HT, only the first two channels will show on the radio. In channel mode it just alternates between CH-001 and CH-002. Even if I save a new frequency as channel 3, it still will now show it in channel mode. All of the frequencies are in the 2m band range, and I'm not getting any out of range errors.
Has anyone seen this behavior before? Is this a firmware issue?
737mech
Clark County, NV.
To be clear are you turning the knob for channels or waiting for scan? Enable scan by pressing */scan key on keypad.
robertmac
I don't think the KG is much of a scanner. You may ask admin to move this to amateur equipment forum.
Perry73
I purchased a Wouxun KG-UV9P. I'm having similar problems. I'd love to get this resolved. Waiting to hear back from Buy Two Way Radios.
