Wouxun radios and narrowbanding.
grogan
I was looking into getting a dualband HT with dual receive and display for 2mtrs and 440. I like that for 120.00 and free shipping I can get A nice radio KG-UV3D. Now Wouxun has A KG-UV6X I see the antenna conector is has changed, 71 more memory cahanels,128 is fine for me.Dual charging slot. also not an issue.Wide receive also not an issue for me because the 3D gives you options on the receive.The UV6X gives you 2.5 khz step for narrow band compliance but cost 55.00 more. Is this a must have feature or just something the new radios will have because of FCC changes. At the present time my budget allows for a 120.00 radio. But for 175.00 I start looking at more radios and other brands and most are not narrowband yet.
mancow
N.E. Kansas
It's a must have if you are wanting to operate on the four decimal place frequencies such as VTAC12 154.4525.
LtDoc
Oklahoma
For amateur use it isn't necessary. If you're going to use it under Part-90 (commercial stuff), then it's a pretty good idea.
- 'Doc
N1SQB
Somewhere On Earth
Grogan!
If you get it from these guys Lentini Communications, Inc. it is only $159.95 for the complete package with the program cable, software and shipping. They give you the single charger not the dual one. This latest version is definitely worth getting over the older one.
Manny
Bubba1661
WV DB Admin
Charleston W.V.
I got my Wouxon UV6D v2 from Universal for $159.00. It came with programming cable and software.
grogan
Ok, Today I called Lenti and placed my order for the KG-UV6D and it should be here in 2 or so days, Thanks for your help. I made my purchase after getting a new job today after a layoff at Thanksgiving. New Job and new radio, I will need it to listen to with all the driving And overtime work I will be doing this summer.
hotdjdave
K9DJW - Senior Member
The Valley (SFV), Los Angeles, CA
KG-UV6X vs KG-UV6D V2
Does anyone know the difference between the KG-UV6X vs KG-UV6D V2? Or are they the same thing?
I can't seem to find a company/website that carries both.
