WQTS973
ctadam12
Wisconsin
Hello,
I found the repeater, but it is NOT at the 950 building. It is across the street at 945 North 12th, atop the Main Hospital building. Should this be reported to the FCC?
bill4long
Indianapolis
Silly reply. I reported the correct information.
You didn't answer the question.
What is your interest in the matter, if there is no harmful interference?
At any rate, if you look at the map of their range of coverage, moving a repeater across the street has virtually no effect.
Thanks for your hall monitor wackerism, but the FCC won't care at all unless they get a report of harmful interference.
ctadam12
Wisconsin
Ok.
OpSec
Monitoring the database
Hello,
Why are you searching out the physical location of repeaters on a hospital down to the granular level of which rooftop it's on? I wish I had that kind of time in my life.
Since a hospital maintenance repeater probably has nothing to do with your life, let it alone.
SurgePGH
Belle Vernon, PA
Hello,
Really?? What's the point in hunting it down? What's the point in reporting it except in the case of harmful interference? Just curious on both points. If you'd like i'm sure you could travel the country and find a million of the same cases and no one gives a crap.
ctadam12
Wisconsin
I reported it. I feel really good. (y)
ctadam12
Wisconsin
And to whom exactly did you report it? How?
I didn't report anything. I work there. I was trying to see if it was normal for addresses to be off, that's all. Johnson (old) equipment is in the 950 bldg, in the elevator equipment room. The Motorola system works great!
belvdr
So what's the point of this whole thread? I'm confused.
ecps92
Taxachusetts
Post #3 you said "I reported the Correct Information" - so alas, Reported to whom?
dcr_inc
Feed Provider *York Pa.*
Delta, Pa
you can reposition up to 1/16 mile without re-licensing anyway.. That close is not worth the extra money or time.. And as you said " Johnson (old) equipment is in the 950 bldg, in the elevator equipment room.".. Its probably off the air anyway
