Wright-Patterson TRS Changes?
jsoergel
Cincinnati/Dayton, OH
I'm not able to investigate, but I've been hearing from a friend that the Wright-Patterson TRS may have changed. Some of the talkgroups are only coming in on the system as currently programmed, while others (like security) are only appearing if scanned on the individual frequencies. This may be a sign that the base/offset has changed somehow.
There was a contract requested to upgrade the TRS to be P25 compliant and link it with the national system housed at Peterson AFB. It may be leaving the 3600-baud and moving to full P25.
If anyone in the area has time, please check and see what you hear. Again, some of the talkgroups are working fine, so you may have to do some digging.
sopranosno1
Follow up from the monix north meeting, here is info we caught heading home from meeting, control channel is 408.9625 p25, here is some function tune info from gre-600, site-16, sys157, n151, r001. talk groups 57021, 57280, security maybe on 57021. Three voice channels so far, 409.9625, 410.3625, 410.7625.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
I went ahead and added this to the USAF system. Hopefully I caught it in time to make the Sunday database download by Whistler and Uniden.
16b
Central Ohio
A friend who works in the Dayton area observed the control channel on 408.7625 today, which is another one of the four control channels listed for the old system. Possible that the new system may use the same four control channels.
MLW1058
Dayton, OH
How do you enter this new system into the pro197? Do you use the same base freq, offset and spacing? It doesn't say on the RR page
jsoergel
Identified talkgroups:
57021 - Security 1
57022 - Security 2
57035 - CE unknown
57039 - CE Heating
57047 - CE unknown
57090 - Code Blue
57121 - Structure 1
57124 - fire unknown
57127 - WPMC
57131 - Fire Dispatch
57135 - Transportation
57170 - Museum
57210 - Supply
57261 - 445 AW A
57262 - 445 AW B
57263 - 445 AW C
57270 - Fleet
57280 - Ground
57281 - Base Ops
57310 - Fuels
57331 - MOCC
57918 - AFRAT
sopranosno1
Dont use the vhf-uhf trunking setting. Use the p25 auto. I tried the uhf trunking setting and got nothing on scanner. Then tried p25 auto and scanner came to live.
nd5y
Wichita Falls, TX
The RR database shows this system with a range of 2 miles, is this correct? It also lists a site NAC, is this programmed into a scanner?
Database ranges often have nothing to do with real life system coverage.
You do not need the NAC to program a P25 trunked system in a scanner.
jsoergel
jsoergel did you observe any encryption? On the old system all the Fire, EMS. and Security was encrypted.
The old system encrypted most comms, but some would pop up in the clear occasionally. For now, the new system is in the clear. I anticipate that changing soon.
brucebuck1010
They are encrypted now. At least security forces. Happened right after that big base-wide exercise a week ago.
Sent from my SGH-M919 using Tapatalk
brucebuck1010
Well make that *some* comms are encrypted - not all.
jsoergel
Fire began encrypting about three weeks after the system appeared, followed immediately by security. A few other users have followed suit. Comments from the Motorola technicians would seem to indicate that the entire system is headed to full encrypted within the next few months.
