wrong install of pro96 usb
RDCat
N.W.
i plugged in the usb cable first-
i have a dell vostro 1700 xp
4usb ports 1 being used for mouse
i put the cd in and nothing happened
i messed it all up!
is there a undo i can do to try to fix this tangled web i'm facing.
trying to get my 106 on win500
thanks everyone
2ManyToys
Mt. Vernon, Iowa
Before a system restore I'd try to install the drivers a couple more times.
Did you try...
  • A different USB port?
  • Restarting the PC & trying again?
  • Are you getting a 'Installing new hardware' message in the task bar?
If all else fails try plugging your scanner in & see if your software can 'see' it.
My .02 cents.
TES
America's High Plains
i messed it all up!
thanks everyone
You might try going to the Win500 Page at Don's website and download the latest version of Win500. Here are the release notes for version 1.74 that was released 24 Jan 2009:
Version 1.74 2009.01.24 18:27 (GMT -0800)
Removed all "COM port" nonsense from the program. Win500 now automatically finds a single connected USB-Scanner Programming Cable, and will prompt you to choose between cables if you have more than one connected (with the option to remember which cable was selected).
You may need to update your cable's drivers to use this new version. If that's required, the program will suggest it. You can get the new FTDI drivers from the FTDI web site.
iMONITOR
Silent Key
S.E. Michigan
Unplug the USB cable, insert the CD, then plug the cable back in and follow the installation instructions that came with the cable.
The CD will not auto-play because there are no programs, or executables to run, only the driver for the cable.
