Swipesy
I resolved the issue. Although I had the latest Win500 Windows 10 driver installed it may have been corrupted. I downloaded and reinstalled the Windows 10 driver and all is well.
Set port to 115200,8,N,1Yes. The main problem was that I hadn't selected the correct port on my pc. After that everything fell into place. I had to use Com 3 port which makes no sense to me seeing that the pc had only 2 ports.
I check your pics and Try to change your bits by seconds at 115200 instead 9600. I have a Whistler original cable for WS1065 for my pro197 and it's work. Also I buy a 20547 cable on Ebay with ftdi chips,install drivers and run #1 too. Do you try to install original driver for your original cable from Grecom website? When you changing bits speed,close psredit and restart after you do it,check your config setting in psr edit. don't forget to choose Psr500 radio. Give me newsI have attached a zip file of my configuration of connecting my PSR-500 using Win500 to a desktop Windows 10 PC. I am using the original USB cable that came with the PSR-500. Occasionally I need to run Device Manager and go to the port that the 500 is on and run "Scan for Hardware Changes" (see zipped file 5) to get it to work. Your issue can only be one of the following (1) bad USB cable (2) wrong Driver (3) PC USB port defective.
My first guess is cable. When I first went to Windows 10 from XP I had similar issues and they were fixed by running Scan for hardware changes on the port. If that did not fix your issue I am suspicious of cable.Still not luck. I'm wondering if I have a bad cable. The led light blinks in the cable when I try to send something over or try testing the port, but the scanner does nothing.
Humm maybe...You need to try a after market cable I think. When i used my Whistler cable, this is my config. If I use my 20-546 FTDI this is my config. Maybe you need to Uninstall alls drivers and start again. Do you try a other computer with Windows7 for example? Give me NewsStill not luck. I'm wondering if I have a bad cable. The led light blinks in the cable when I try to send something over or try testing the port, but the scanner does nothing.
In Whistler's website - user guides: there is a step by step manual of sorts for both the Win500 and PSREdit500 programs. You'll have to scroll down to the bottom of the scanner manual list to find them.I've tried using PSR500 and Win500. Win500 recognizes the cable but does not communicate with the scanner. PSR500 does neither. I also bought a 20-546 cable and tried that with no luck either. Unfortunately, all of my computers are updated to windows 10 so I can't try an older version. The directions that came with the scanner leave a lot to be desired on how to program this from a computer. There is no certain mode that I'm supposed to be in on the scanner, is there? Am I missing something?
