WS 1080 not receiving well
436isthe1
Whistler ws1080/Uniden 436hp/GD-77and Cobra 29 ltd
Missouri
Hello I have a GRE COM 800, Whistler converted it to a WS 1080. was working great until lately . My unit isn't receiving that well, every time update or had channels through EZ Scan my unit does not receive well. I contacted Jon at Whistler he stated to get a new San Disk memory card, I did and formatted it and still have the same issue, ever since I updated my unit through EZ Scan I have had this issue. Basically it does not receive or it is very slow to receive. Any ideas?
tvengr
Well Known Member
Baltimore County, MD
If you have the problem since reprogramming, it sounds like a problem in the file. Please attach your archive file and I will take a look at it. You should be using the WS1080 EZ Scan. What is your city and county? Check if the attenuator is turned on and your squelch setting.
436isthe1
Missouri
I do use EZ Scan
436isthe1
Missouri
I THINK THIS IS IT.
  • CDAT_2021-01-02_19-51 - Copy.zip
tvengr
Well Known Member
Only scan lists 1, 2, and 3 are enabled in the file. If you reprogram, you turn off all scan lists except the first three. Also, try a different antenna.
436isthe1
Missouri
I don't see anything obvious in the file. Try using a different antenna.
I have. Same
No Simulcast issues at all.
I only want list 1-3 on when I scan. other lists are extra.
Have to turn my unit on then off again to receive anything.
436isthe1
Missouri
Time varies, Worked great before upgrade. No warranty. Also the issue only seems to be on DMR channels I have in a list.
tvengr
Well Known Member
It's beginning to sound like a possible hardware problem. Components can fail after heating for a period of time. You can also have leakage currents in components which set up a time constant and can cause failure after being on for a while. Bad solder connections can cause similar problems. Try removing the cover and check to see if there is any corrosion on the circuit board.
436isthe1
Missouri
I receive all WX channels conventional anolog P25. Just acts up on Dmr
