Ws 1080 squelch settings
troymail
Silent Key
I typically keep my squelch at about "10 o'clock" (there's an indicator around the dial that suggests this is a good place to set it). Of course, every situation is different. However, extreme (full) clockwise or counter-clockwise is not normal.
jaspence
Michigan
Turning down the squelch has been suggested when monitoring P25 in other postings I have read.
Wackyracer
Try deleting all the data on the sd card then copy the configuration TO the scanner from ezscan. It could be some data didn't copy correctly.
