WS 1088 Can't connect to computer
kf6mxk
Tehachapi,CA
It keeps saying that the scanner is not detected. I using the same cable that works great for my TRX 1 . I have downloaded the driver from the whister website. I have tried holding down the menu button when connecting the USB cable.
ka3aaa
middletown, pa.
the scanners baud rate and comm port must be set just like the softwares baud rate and comm port.
Wackyracer
with the scanner and its programming software, wx 10 has nothing to do with it.
ws1088 uses ezscan.
You must have the scanner OFF.
Try a new data cable, if he has the same issue, delete the comport driver and reinstall.
Ronaldski
MI DB Admin
Bay City MI
These things can be finicky from personal experience. If it doesn't connect, what will work is remove the sd card with scanner off.
Put the sd card in one of those sd card adapters, put that in your computer and I can pretty much guarantee it will update that way. Then once done put it back in the radio.
Nascar18
Southeast Massachusetts
Someone with a Whistler scanner just had the same problem. It was the USB cable they were given. Try another USB-B cable that transfers data.
