WS1040 Conventional Question
DrUnKeN_TiGeR
So i have a Regular scanner that scans my local fire department frequency and it picks up a lot more than my whistler does. Are there any changes in can make I the programming of the whistler to make it pick up better? Such as squelch type or anything else? The current squelch is set on DCS. Thanks for the help.
DrUnKeN_TiGeR
thanks i will try that, i imported from rr so i just went with what it defaulted too.... so upon trying that. i have DCS, CTCSS, P25, search and none
krokus
Southeastern Michigan
What is the other scanner? Is it programmed with more frequencies and/or talkgroups?
DrUnKeN_TiGeR
Trunk system, another Scanlist.
its not an issue where it doesnt scan to the frequency it hits the frequency transmits for a few seconds you start to hear the transmission then gets staticy then stops
