Ws1040 scanner
morgan151
Hi all
I just uploaded to my ws1040 scanner,
using PSREdit500 it worked fine,
loaded all the Trunking Objects,
But how do I upload the,
Conventional objects.
Thank You,
bob550
Albany County, NY
Using PSREdit500, click on Import, Import data from RadioReference.com, and Conventional Data. Log in to RR.com Web Services Import for Conventional Data. If your country, state, and county are selected, select the agency of choice, category, and sub-category. Make sure to select the frequencies you wish to download and proceed as you would for trunked frequencies.
hiegtx
Dallas, TX
Hi all
Thank You,
By chance, did you create two entirely different files in PSREdit500? One file with trunked systems. the other with conventional frequencies"?
For the WS1040, and the related models using the same Object Oriented programming (such as the WS1065, original PSR-500 & -600, among others), you can only use one file at a time. While you can have additional programming files stored in the various V-Folders, you can only scan one at a time. So, if you have a file with only trunked systems, if you were to upload a second file with your conventional channels, then that would override your trunked system programming, and the only thing you'd hear would be conventional systems.
You need to program your file with whatever trunked and conventional channels you want, all in one single file. You can still control which ones you are hearing by using separate scan lists, which you can toggle on or off whenever you wish.
As bob550 has already noted, you can import the conventional channels you want into your existing trunking systems file, then load the expanded file, containing both types of systems, to the scanner.
morgan151
thanks all for your assistance
scanner loaded and working ok.
