WS1080 on Win 8 / 8.1 driver instructions
baayers
Pinellas County FL
The instructions below were originally posted a couple of years ago by MORSEMAN but I modified them for the WS1080 since the driver signature issue still exists. It might be worth stickying this for a while since it will be in the hands of a lot of new users in the near future and a newer firmware is already out.
1-When you are signed in to Windows 8 / 8.1 as Administrator connect the WS1080. It will then attempt to load the driver and appear to succeed but the driver will not be working at that point. Even though the serial driver is not correctly installed you will still see the scanners MicroSD card.
2-Copy the INF folder from the WS1080 to a folder on your computer
3-In Windows 8.0 While on the start load the Charms Bar by pointing the mouse at the upper right hand corner of the screen.
4-Select Power and hit restart while holding down the Shift key.
5-A selection of Troubleshooting options will come up, select the Troubleshoot option
6-Another page will appear, select Advanced Options.
7-The next page will display several repair options, Select the Startup Settings to change the behavior of Windows Startup and then click restart on the next page.
8- A menu with 9 selections will appear. Select #7 or F7 to disable Driver Signature enforcement.
9 Windows 8 will restart.
10-With the WS1080 still connected open Device Manager from the Control Panel. Select the Com port assigned to the 1080 and select Update Driver.
11-Select Browse and point it to the .inf file located within the INF folder you copied from the 1080.
12-Install this Driver. An alert screen will pop up to warn you that this is an unsigned driver, Select install anyway. This will load the unsigned driver and allow it to work with EZScan
13-Check to see if it is working by Starting EZScan and selecting Scanner SD Card and select to set the Real Time Clock to Computer time. If it does it successfully you are good to go.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I'm not seeing multiple questions on the subject so I'd say let the users search for the answer.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Sorry, didn't quite fully explain.
We're trying to avoid a lot of Stickies in the forums so I'd rather not sticky this.
What we can do, is put a link to the thread in the archived stickies thread.
baayers
Pinellas County FL
Sounds good to me.
My only intent was to help some one who may be running into this for the first time.
Thanks for your help
buckbull
im in the same boat I have ws1080 and windows 8.1 . and I was wondering if someone can tell me where the inf file is ? when I insert my micro sd card and all the folders pop up I went in every folder and didn't see the inf anywhere ???
its stopping from getting updates thanks !
xp
Here is the page on the Whistler website with the instructions baayers posted. Click on the Scanner FAQ link to see them
Whistler Group - FAQ
Mike
That does not work for the 1080 on XP. You need Windows 7 or higher the driver is for 7 -up. Beat that to death all yesterday,I ended up with Windows 7 and now it works by itself.
mikeshepard
El Cajon, CA
Just got a new laptop with Win 8. I'm sure this is aa dumb question, but where is the INF folder located? I don not show such a folder or file when I look at the scanner in explorer.
jamesmccarty
Grand Prairie, TX
Hi Mike.
I don't see a response to your message. In checking my WS1080 I have an INF folder off of the root of the memory card.
tlangshaw
Kansas City, Kansas
Mike, I had to go to whistler site, click on find updates, click on scanner radio, click on WS1080 Deleted/Reformated SD Card EZ scan IS installed on pc. When you scroll down you will see WS 1080 Scanner Drivers, download that and it will be inf. It was not on the root of my memory card either.
baayers
Pinellas County FL
Does anyone know if the drivers on Whistler website are updated and resolve the driver signing issue? I have been wondering this but since I already have the old drivers working you know the saying about not fixing things that are not currently broken.
