wsjt waterfall
jazzboypro
Laval
Hello all,
I seem to have a gap at 1500 on the waterfall, nos signal at all. It does that on every band. I'm pretty sure it was not always like that. Any ideas ?
jazzboypro
Laval
What radio? Do you have a notch filter turned on?
The radio is a 7610. I played with the notch filter settings, the gap was shifting on the waterfall but it remained there. I then played with something called SFT and that solved the problem. I will have to look in the manual and see what it does. I did noticed that the BW of filter 3 was changing as a changed the SFT value.
AK9R
Staff member
Super Moderator
Central Indiana
SFT? That's shifting the pass band tuning.
If you have either the automatic notch filter or manual notch filter turned on, turn them off. You don't want them getting in the way of WSJT-X's ability to decode the entire passband. On the radio's display, near the meter, if you see an icon that shows "AN" or "MN", you have the notch filter turned on. Tap the MULTI knob. The fourth item from the top in the pop-out menu on the right side of the display will be "NOTCH". Each time you tap the "NOTCH" item, it will cycle OFF-AN-MN and back to OFF. You want it to show "OFF".
Back to the passband tuning...tap and hold the TWIN-PBT knob to clear the shift. Tap the FILTER button to cycle between the three filter settings until the "BW" shown on the display is the greatest, probably 2.9k.
jwt873
Woodlands, Manitoba
OK.. If the manual notch was on, you should be seeing the same black strip showing on your radio's waterfall as well. The auto notch wouldn't cause a solid black stripe. Auto notch should be bouncing around trying to lock on what it thinks is an interfering signal.
The soft/sharp IF passband setting shouldn't cause the black strip... You're only changing the shape of the skirts on the upper and lower limits of the passband. Nothing changes in the middle.
In SSB-D mode, Filter 3 has the narrowest bandwidth.. (500 Hz by default). I use Filter 1 and I increased the default 3 kHz bandwidth to the maximum of 3.6 kHz for better performance up on the high end of the waterfall.. I select this bandwidth whenever I run FT8.
When you're in SSB-D mode, the radio should show your bandwidth.. It shows up above the right hand VFO.. eg BW x.xk
jazzboypro
Laval
The notch filter is off and i cleared the shift. It's all fine now.
I also use FIL1 at 3.6 kHz.
jwt873
Woodlands, Manitoba
Great...
Every now and then I'll leave something on. Passband tuning or whatever, and then wind up figuring out why I've got a big dark area on some portion the waterfall. :)
W1HD
Golden, CO, USA
Hello all,
I know you've solved your problem already. I'm just commenting to say that your notch filter is really great! If you pursue CW or SSB you will love having that skinny, steep filter.
jazzboypro
Laval
Thanks for the tip, i have been mostly on FT8 for now but i plan on using SSB in a near future.
