autovon
Ø
- Joined
- Jul 10, 2008
- Messages
- 416
WWV is testing on 25 MHz. From the website: NIST Radio Station WWV
NOTICE: Experimental 25 MHz WWV Broadcast
As of Friday, April 4, 2014 WWV has resumed broadcasting on 25 MHz on a limited, experimental basis. The broadcast consists of the normal WWV signal heard on all other WWV frequencies, at the same level of accuracy.
Current 25 MHz Broadcast Specifications (subject to change):
Schedule: variable; as an experimental broadcast, the 25 MHz signal is not continuous. It will typically be on the air from approximately 1500 – 2100 UTC Mondays through Fridays, but may operate outside these hours as well. The broadcast may be interrupted or suspended without notice.
Radiated Power: varies; no more than 2500 W
Antenna: broadband monopole, coordinates: 40 deg. 40' 50.8"N, 105 deg. 02' 32.6" W
Listener comments and reception reports may be emailed to: wwv@nist.gov, or sent via postal mail to:
National Institute of Standards and Technology
Radio Station WWV
2000 E. County Rd. 58
Fort Collins, CO 80524
Radio Station WWV
