- Joined
- Nov 30, 2010
- Messages
- 48
I have a single DMR system programmed and scanning, which works great. It is the only item that I am monitoring, so it stays on that system and doesn't scan anything else.
To be alerted when weather warnings are issued, I have turned on the WX Priority feature. This, of course, causes the radio to leave the DMR system every now and then to search for the 1500Hz alert tone on the analog weather frequencies before returning back to the usual monitoring. That's expected, and I can see the switch happening by the fact that the CON+ indicator (showing that the DMR system is being decoded) goes away momentarily every few seconds.
The problem is, though... it never alerts. I have been monitoring the local weather frequency on a different device, and there have been many warnings issued with the 1500Hz alert tone, and I have visually watched the scanner leave the DMR system I am monitoring to check the weather frequencies, but there's nothing.
If I monitor only analog frequencies (for example, a favorite list that I have that has only analog frequencies), the WX Priority feature will alert as expected.
There seems to be some kind of bug with the reception of weather alerts when a digital system is the only thing being monitored.
Anyone else able to reproduce this?
