mike_gain
Purdy Kull
Console looking slick, now if there are storms to chase and your off work!
Not much done on the console today. The weather was exquisite so I worked on the UHF Yagi for the DMR radio. TDMA does not work or play well when it has multipath issues so I raised the antenna to clear some obstructions. I got from -100 to -80 DB worth of improvement so I'd say it was a day well spent. More metal massage to come....
It's kind of comical that Solid Signal lumps all antennas into the "CB" category...
You want a good chuckle do an e-Bay search for "Motorola CB" it's also a GREAT way to get a great deal on some radios but you'll meed your Mother BATWING decoder ring to figure out what is listed.
I'm curious, how do you have the coax run to the antenna(s)? I'm guessing you have it run into the attic and out the roof?
The coax is routed through a repurposed hole in the wall graciously drilled by a huge over priced cable television company. then up the side of the house and along the gutter.
