Wyoming HP AXO Tag?
N0WRE
Cheyenne WY
Morning all,
Was downloading the talk groups for WHP and noticed a AXO tag for Cheyenne, can someone clarify this as I didn't see an X for counties.
Peter
whp3310
Buffalo, Wy
My reasoning For AXO listing,
A-Patrol Division
X-Executive Detail (For Govenor)
O-Dispatch Operations
This is my take on the meaning, but a very good question that should get more responses down the road.
mtnfireguy
NE Wyoming
It means that talkgroup provides coverage for
Division A
Division O
Division X
Divison A is the Patrol Division for Laramie County
The others are the Captiol Security and Headquarters division's
N0WRE
Cheyenne WY
Thank you all for the information, the reason I asked is I did not see a division X in the list on the web page so I was curious as to the X n the talk-group listing. If its for the executive (governor) listing is it possible to change the web page to add this to the description in the table?
KG7JEV
Cheyenne, WY
Usually what I do, is adjust the id tag in my software for what I want displayed (i.e., instead of "Laramie CAT1, mine says "02 CAT1"). It's my understanding WHP uses the same TG for all of the above and there's not a specific TG for just capitol operations (I may be wrong).
N0WRE
Cheyenne WY
I'm using the ARC96 software to program, I will have to find out how to rename tags. On an off note can you put trunked and conventional in the same bank? I am still playing with the software and want to make sure I can do that for scanning purposes.
hpycmpr
Los Angeles County, CA
Yes, you can mix any channel/talk group in scan lists. At the worst too many can slow down the scan a bit.
I tend to keep large trunked systems separate from my conventional channels for convenience. Wyolink is a large system for my 500/600 radios. Therefore I break it up into separate TSYS by regions. By keeping the conventionals separate I don't need to repeat them in each scan list.
Steve
mtnfireguy
NE Wyoming
To Clarify
Division A is the Laramie County Patrol Division
Division X is Headquarters
Division O is Capital Protective Services
They all operate on the same talkgroup, hence the AXO tag
