Is there a better way of chaning the USB cable from Serial to Mass Storage other than unplugging the cable and plugging it back in?
The scanner has to be in Mass Storage to upload profiles and Favorites Lists, but has to be in Serial to use things like ARC 536 Virtual Control.
Also is simply unplugging the cable the best way of disconnecting the scanner from the computer, or should one do as one does for an SD card (as in "Eject")?
