x36hp/sds sentinel One Freq Trunk P-Ch (Pri)
bravo14
Polk County FL
On One Freq Trunk when you put in talkgroup and slot and go to P-Ch it is not selectable. Is there a way to change that? Some people ask me about it for over a few years about it. @UnidenSupport
ofd8001
Louisville, KY
If you were to compare the Options for a 1 Frequency P25 system with a "regular" P25 trunk system you will see that there is no Priority ID Scan option. Since there is no Priority ID Scan, there isn't a reason to set priority channels.
Why there is no option to do Priority talkgroup scanning, I am unable to explain other than hazarding a guess is that there is no reason for a priority due to the nature of the system.
hiegtx
Dallas, TX
That would be similar to my guess. On an OFT system, you can only have one transmission in progress at a time. There is no "other frequency" for the scanner to review, since it can only receive one signal at a time. Unlike a true P25 system, where there is a control channel that can be checked for a Priority TGID in use, there is none for an OFT system.
