XG-100M Programming Problems
AF1UD
I recently joined the XG-100M/P club after doing some research on this forum and several others. I did the portable first and changed it to the Mobile (CH-721) and I got nothing but 0500T errors (see attached). I rewrote my code plug and made sure to override the programming through RPM14 (third option) and it is now working. It seems to be working with Non-Affiliate Scan.
However, can I have multiple mission plans? Or am I limited to just the one with the mobile? Also, do I need to mess around with any of the audio settings for the speaker?
nikronzo
No, only the 100M with a CH-100 control head supports multiple mission plans (10 of them to be specific)
AF1UD
I am getting low to no audio out. Any idea why?
Also, the the radio restarts when receiving.
BMDaug
I am licensed…
Central Colorado, USA
Where are you connecting the speaker? If it’s not the round connector in the back of the remote mounted 721, what pins are you using on the accessory port?
-B
AF1UD
Turns out it was there was a loose connection in the speaker wire. works fine now.
Teotwaki
SoCal
Glad to see the issue with error codes went away! In one mission plan you can set up a lot of groups or "systems" to cover agencies and other groups of frequencies.
2154
Many times the error you're seeing is from programming with too new a version of RPM/RPM2. If you're still on R02A26 firmware, I'd definitely recommend updating that. R06T02 was the last version for the Unity and it works just fine with RPM14. You can make the jump straight to R06T with no issues though may also need to update your burn/boot app (versions 13 and 12 now respectively).
