XG-100P keeps dropping and reacquiring control channel
merlin
DN32su
In 90% of these cases, the problem is alignment. the other 10% programming errors.
merlin
DN32su
Viavi 8800sx will autotest the Harris XL and XG series. It's a licensed feature in the test set, so it's something that has to be added. A radio shop that carried Harris radios would likely have it.
The Astronic Freedom service monitors will do it also.
Personally, I would go with IFR (Aeroflex). They do it.
W4KRR
Coconut Creek
Broward County, FL P25 Phase II; Coral Springs FL Phase 1; Fort Lauderdale FL Phase 1.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
1 and 2 should be FDMA. 3 and 4 should be TDMA.
Edit: This is assuming all 3 systems are Motorola. Harris and other systems use different band plans and put the TDMA channels in 9 and 10.
Appears they're all Motorola, so should be fine if he simply swaps the Type settings. I'm not 100% sure about the frequency in #4 though; it's in my head that it should be 762.0125 MHz.
Unless something changed, support for the XG-100P ended 2 months ago.
I figured it was around now; good thing I take care of my toys (although I've got a good relationship with my Harris shop, so if something broke they'd do their best to fix it).
