XG-75 VHF reception
Syncopations
Hears voices in my head.
South Texas
Scenario: XG-75p VHF P25 and P7100 VHF P25 with identical programming. Radios sit approximately 5 feet apart and on scan. The P7100 has no trouble receiving traffic, while the XG is struggling to decode the signal. When the radios position are switched, same result. P7100 has no issues at all.
Any ideas as to why this may be happening?
Thanks.
Syncopations
South Texas
Have both radios been recently aligned?
Sent from my SM-G950U using Tapatalk
As far as I know, the answer is no, but we do believe that could be the issue. The XG is going to the bench sometime this weekend or early next week to see if it needs alignment.
I forgot to mention that if we move the XG around, or even hold it up in the air, it'll receive traffic, but there is a slight squelch in the beginning of some P25 transmissions.
DisasterGuy
Maryland Shore
The alignment and sensitivity test should give you a good indicator. I will say that we found on analog EDACS that the 700p and P7100 appeared to be more sensitive than the XG-75p from user reports even though I was never able to replicate it on the bench.
