XG-75P ACC license locked
arbitergvadam
San antonio
I have a pair of XG-75P UHF radios that I attempted to read using RPM1 software and I get the following error
ACC license required cannot write to set
Does this mean the radio is basically a brick or can this be resolved somehow in the RPM software?
I have RPM 1 and 2.
Model of the radio: EVXG-PBU1B
BMDaug
I am licensed…
Central Colorado, USA
That should just mean that there is a trunked set already programmed and you cannot modify the trunked program because you lack the necessary system key(s).
You should be able to just write a new program to the radio with your own channels/systems. It’s just telling you that you can’t modify some of the read programming.
-B
arbitergvadam
San antonio
ok, glad there is some hope thanks, I thought I brought home a fancy plastic brick. do you Recommend using RPM 1 or RPM 2 to attempt programming?
BMDaug
I am licensed…
That shouldn’t matter. I’ve never programmed a 75, so I can’t speak to the differences in programming. All I know is that you get errors like the one you describe when you lack system keys for the system in the read program.
-B
merlin
DN32su
RPM 14C05 works great for your radio and a lot easier to get than RPM2.
