XG-75P questions
W4KRR
Coconut Creek
I have an XG-75P with R06M03 firmware. Should I be able to read/write with RPM R14C05?
Also, is there a contrast adjustment for the display? I couldn't find one.
wa8pyr
Staff member
Lead Database Admin
Ohio
Only if it hasn't been written with RPM2 previously. I've never tried writing an RPM codeplug to a radio that had been written with RPM2 (once I started using RPM2 I never went back to RPM except for my XG100P).
If that menu choice is enabled, yes.
W4KRR
Coconut Creek
Thanks:, I just found "Contrast" in one of the front keypad drop down menus.
RayAir
I have one that came with R06M03 and a personality version of 95.0. I could write to it with R14C05.
W4KRR
Coconut Creek
Question: I have created a custom scan list. There is a menu item called "CUSTSCAN", but it doesn't allow me to view or select anything.
If I understand what I have read correctly, I have to select "Enhanced Control Channel" for the custom scan list to be usable?
Also, all talkgroups in the custom scan list must have the same WACN and system ID for it to work?
No conventional channels involved, NAS scanning only.
wa8pyr
Staff member
Lead Database Admin
Ohio
I haven't done custom scan quite as much with an XG75, as we mostly use XL200 portables. However, that menu selection should allow you to select the list you wish to edit, and once you're in it you have to select the "edit" selection. Clear as mud, right?
W4KRR
Coconut Creek
Well, selecting "CUSTSCAN" and then pressing "M" it then just goes back to the main display.
wa8pyr
Staff member
Lead Database Admin
Ohio
I'll have to play around with a couple of the XG75Ps sitting in my office when I get back on Thursday and let you know, if you haven't figured it out by then.
BMDaug
I am licensed…
Central Colorado, USA
Never used a 75… but you create the custom scan list in RPM, then assign it at the system level. Once assigned, you can switch between the system scan list and the custom scan list, where you can edit the scan members from that menu. I’m not sure you can just create a scan list from scratch on the 75.
-B
W4KRR
Coconut Creek
Another XG-75 question:
Is there a way to use cheap earbuds for listening only with the XG-75P? All of the audio adapters I have seen for this radio use a Hirose or QD "Quick Disconnect" connector. Most cheap earbuds have a 3.5mm stereo connector. I can't find an audio adapter for the XG-75 that has a 3.5mm audio jack.
BTW, is a Hirose connector the same thing as the "Quick Disconnect" connector I have seen on some of these devices?
BMDaug
I am licensed…
You may need to find or make a hirose to 3.5mm. You could also use a Bluetooth adapter. They make one that connects to the udc.
-B
W4KRR
Coconut Creek
-B
I've seen some Hirose to 3.5mm adapters; plus I would need the adapter that attaches to the radio. Or I could go with bluetooth; those adapters run around $100. Also I've seen some aftermarket speaker mics that have a built in 3.5mm jack. I just have to decide which route to take. The aftermarket speaker mic would probably be the cheapest. Some of the listening solutions I have found cost almost as much as I paid for the radio!
