XG-75Pe 7/800 Band Split
MikeNike42
Iowa
I see the band split for the XG-75Pe is 768-861 MHz. Would this split include 861.0625 MHz or would this be out of the band split range?
wa8pyr
Technischer Guru
Moderator
Ohio
Doesn't work in RPM or RPM2, and for good reason.
861-862 MHz is the post-rebanding "Guard Band" intended to limit interference between the 851-861 Public Safety/PLMR bands and the 862-868 ESMR band. It's not available for PLMR use, and any users who were there should have been relocated during rebanding.
RayAir
Over here they just reassigned (within the last year) a lot of the 861 and 862 mhz frequencies from an old statewide EDACS system (energy company) to the statewide P25 trunked system's sites.
So they're still in use.
wa8pyr
Technischer Guru
Moderator
Ohio
They must have gotten a waiver, then (although why they would still be in the 861-862 area after all the fuss over rebanding is a head-scratcher). 862 is definitely in the ESMR band and out of bounds for PLMR, and 861 is guard band, which isn't supposed to be used. Most post-rebanding radio models won't even allow use of those frequencies.
Forts
Ontario, Canada
Those frequencies are also alive and well here in Canada if you happen to be along the border. There are many trunked systems in Ontario that are in the 865-868 range.
