Xg100p no audio
KN4EHX
You’d know much better than I would. I said PRC-152 and perhaps my nomenclature is off. I was under the impression it was still being used, but that is wayyyy out of my area of expertise. JTRS and FirstNet typically get grouped together in big money spending flops of the century categories.
Entirely possible HRT is using the new waveforms, but again that is way above my head. They deploy internationally and very frequently train at JFK Special Warfare skoo I wouldn’t be shocked to learn they have a need for that and an APX8000.
I gotta know did they keep the pogos?
TDR-94
IF im not mistaking, i believe the Falcon PRC-152 has been is pretty much obsolete operationally in the us military
Your probably thinking of the PRC-148. The US Army started the phase out of the PRC-148's in 2013. They were the largest purchaser of them.They intern replaced them with PRC-152's and some THALES MBITR 2's were also purchased for a specifc US ARMY unit.
TDR-94
The new Falcon IV PRC-163 uses pogo pins, The public safety radios had been using pogo pins for the battery and other internal connections since the advent of the Com-Net/Ericsson/M/A-Com Jaguar 700P.
The pogo pins on the XG-100P are less robust than on the HARRIS or THALES military handhelds and thinner than the previous ones used on other HARRIS aquired public safety radios.
rescue161
KE4FHH
Hubert, NC
I am by no means an expert on Harris gear. I can only offer my experiences with the several thousand radios that we manage.
AESFTW
Its a known issue, I have had a handful with bad speakers, just randomly go dead. Works fine with a speaker mic attached, just nothing out of the main speaker.
I have seen this issue with the internal microphones. Connect a speaker mic and all is good, otherwise all you get is carrier.
apco25
Batlabs OG
Amundsen-Scott South Pole Station, Antarctica
These radios do not suffer from "replicant" errors. Your need to comment incorrect info here is just as bad as on Facebook.
reload the mission plan.... REMEMBER NEVER EVER read a out a radio modify contents and write back as u run the risk of a replication error... if if you have to modify a mission plan, do so from one saved on your PC and and overwrite the existing one on the radio. heres something a replication error compares to in a simpler sense: you make a photocopy of a any document, then photocopy that copy... the 3rd photocopy is not going too look anywhere near perfect when u hold it side by side to the original document.
