Xg75m (invalid encr grp)
Radioman62
Was: Tigersrulz.
on my Xg75m when encryption is enabled on ARC4 it say (Invalid encr grp) on the display and I can’t hear the encrypted & unencrypted TG’s. I have checked all 5 set of encryption keys and everything is right. I have feature 61. My setup is this
Burnapp- R13E05
BOOTAPP- 12
ECP/XGP - R06D13
OTP/VRM- N/A
MCU- R06.03.00
VRB- N/A
CH721/CH25 main app - R04.02
RHHC - N/A
AEC load module - N/A
DES load module - v02.08
Thanks for any help on getting this to work.
fuhwurd
「喜べ、少年」
Hawaii
Burnapp- R13E05
BOOTAPP- 12
ECP/XGP - R06D13
OTP/VRM- N/A
MCU- R06.03.00
VRB- N/A
RHHC - N/A
Did you set the correct key number?
Radioman62
Was: Tigersrulz.
Triple check everything in digital voice and private voice options. Make sure it’s set to ARC4 and not AES
Have triple checked everything. All I can figure is it a firmware issue. I am about to give up and just use my portable.
fuhwurd
「喜べ、少年」
Hawaii
Super weird since INVALID ENCR GRP only pops up when you didnt properly load the talkgroup IDs in keyadmin when doing AES encryption. If it is indeed firmware id recommend upgrading the FW when you find it. I never tried ARC4 encryption since they werent on the feature set of my harris radios so take what I say as a grain of salt.
If you have feature 53 enabled I recommend using the DES in private voice since it is way much more better than ARC4.
wa8pyr
Staff member
Lead Database Admin
Ohio
Its not a firmware issue. I have 3 XG mobiles on R06D13 running ARC4. It's your programming.
Ditto. I’ve used ARC4 on several different Harris radios with different firmware versions. Never had any problems.
