Xiegu x6200 antenna tuner stuck and not working
n2ann
Hi everyone,
I have been using my Xiegu x6200 reliably (and happily) for about 6 months and recently completed the firmware upgrade to v1.0.6.
Things were working fine, until I accidentally activated ATU while there was no antenna connected to the radio. Now, when I connect an antenna or dummy load, the ATU seems to be stuck and cycles/clicks for 15 seconds but does not show any power output or SWR reading (both at zero).
It seems like the relays are stuck in a bad position that is "out of range". Is there any way to reset the ATU relays? I've done a factory reset and even downgraded the firmware back to v1.0.0 with no luck.
Thanks in advance for any help you can provide.
Kind regards,
Mike N2ANN
