XL-200P WiFi Issue
ThreatLevelMidnight
Georgia
(New to the XL world)
Anyone have any idea why the WiFi client menu would be doing this? I know for a fact that I do have the LTE and WiFi boards, and options installed. Works fine on WiFi programming mode to RPM2 as well. I have set up the SSID and password in RPM2.
nikronzo
Wifi doesnt turn on unless it needs to be on, AKA either wifi programming mode or broadband service (BeON or MCPTT).
WB5UOM
Harris rep in a meeting a week or so ago said wifi could be programed to turn on automatically or manually.
Never played with any Harris and dont want to.
nikronzo
Having a CCM on the XL does not predicate the wifi being always on, theres an option in RPM2 that allows the LTE CCM to be always powered on for those users wishing to use LTE broadband failover. I hope that a future release of XLP will allow the programmer to keep wifi always powered to lower the time it takes to roam.
USCGTC1
Washington NCR
I'm a little confused. When enabled, is the radio broadcasting a wifi signal ( HARRISradio) for the PC to find and connect to? or is the radio suppose to connect to your home wifi and get an IP address for the PC to connect?
BMDaug
I am licensed…
Central Colorado, USA
For Wi-Fi programming, the radio connects to a network. It does not create a network for programming purposes. Follow the instructions in the manual for proper network setup and programming. The great thing about the radios joining a network is that many radios can be programmed in a single go!
-B
USCGTC1
Washington NCR
-B
Got it thanks!
