XL-95 Changing Zones
ScanFanEd
Southern California
I saw a Harris cut sheet that mentions the XL-95 having an A/B/C switch, with the sixteen channels selectable for each of those positions. Does this mean that the XL-95 does not use the arrow-up and arrow-down buttons for changing zones? Perhaps both ways are an option?
Thanks!
Forts
Ontario, Canada
It all depends how it's programmed. The ABC switch can be programmed for Zone banks, Systems etc. Or you can do it via the keypad.
rjschilder
AES FTW
The XL95 doesn't have arrow up or down buttons. It does have three programmable buttons across the top of the keypad that can be assigned to system or zone up/down.
Forts
Ontario, Canada
But you have 2 buttons on the side of the radio that could be used for zone up/down. Also the up/down/left/right in the middle of the keypad can be used for Zone control, among other things.
rjschilder
AES FTW
True, but the physical up/M/down only buttons like on the p7100/7200/7300/75/75pe don't exist. That's what I meant. Sure, you can map any button on the radio to whatever function you want.
