XP-100G Scan List
gdsteele
I think I have firmware V12. Radio Info has for SOFTWARE: 12082-8900 XGPRO2A26.
If I press <MENU> <SCAN> <SCAN LISTS> my radio acts like it was turned off and back on, it reboots. Has anyone else experienced this? Did I do something wrong setting up the Mission Plan? Any ideas?
Thanks,
Jerry
rescue161
KE4FHH
Hubert, NC
Your firmware is R02A26 and you should be using RPM 10B to program. If you programmed with a different version of RPM, you may have enabled a feature that isn't recognized with 2A26, hence the reboot. There are a few places in RPM that you have to set up for scan lists and if you missed one, it will hiccup and reboot as well. Make sure that you have every channel in your scan list set to scan under the group sets/ conventional sets. Make sure that you have the Scan Options set to your preferences. And make sure that you have Custom Scan Options set correctly. Things can also get wonky if you are not using Zones, but are pointing to Systems instead or the other way around.
TDR-94
Custom Scan isn't officially supported with R02A26 and, if selected, is buggy as hell and will usually end up with the radio crashing.
gdsteele
I truly appreciate your answers and you were right on the money. I was programming the radio with an version of RPM what was newer than 10B. I have since upgraded the firmware and all is good. I knew that SOMEONE had seen this problem before. You can always rely on RadioReference.
