Xpr 3500e mdc burst chirp
Sam216
Hi I have a motorola xpr 3500e and mo matter what coast time or auto mute duration I put it always seems to give a small bleep instead of the regular chirp any suggestions or help
I've tried the standard 275 and 150 still not consistent. once in a while will it give a full Chirp and when it does its usually when im farther away from the other radios. seems like the farther I go the more chirp weird
Sam216
No I’m trying to have it make the standard mdc chirp
But it’s weird. It seems like the farther away a radio transmits a signal the more of a chirp it is, but the closer a radio transmits a signal to my xpr the more it’s a half chirp more bleep sound
K2NEC
5F6
Simply unelected the MDC system for RX in the personality
Sam216
How would that give the chirp you kinda need an mdc selected in the rx to have the channel decode mdc
(Ps using cps2.0)
K2NEC
5F6
Because youre muting it with the MDC System. Disabling the system will not mute it at all.
Try setting everything to 0
Sam216
I’ve done that and it just lets the full mdc burst come through
The main settings that determine the chirp settings is the dos setting options
Sam216
Instead of the standard mdc burst sounds I just want a consistent chirp sound
tweiss3
Is it time for Coffee?
Ohio
You want a chirp on receive, or when you transmit?
tweiss3
Ohio
Is the system using beginning of transmission (BOT) or end of transmission (EOT) for MDC? Are you scanning? If you want to hear the MDC, either turn off muting to decode unit numbers, or disable the MDC system and just put the channel in as an analog, both described to you above.
Sam216
The base transmits eot and so do the other radios
All I would like to hear is replace that awful mdc burst when the base transmits or another radio for the regular well known chirp sound
I’ve tried playing with coast time ans auto mute duration
I’ve tried all the commands 150 ms 100ms and 275
And just never seems to be accurate like I said previously the closer the signal the more of a bleep it is the farther the signal the more of a chirp it is
tweiss3
Ohio
So you want to mute the MDC, but hear an EOT chirp similar to the talk permit tone? I'm not sure how to set that in Mototrbo CPS, or if it's possible.
Sam216
Kinda not exactly Just look up mdc dos chirp you will understand what im trying to do
