XPR 3500e trigger alert on Quikcall Page
estone4009
Philpot, KY
I have an XPR 3500e that I want to trigger a call alert on a page. I have the signaling system setup, contact setup and channel setup. It is muted until triggered but will not trigger for my tones. Using another department in my area triggers the tones so I am guessing I am close on setup just maybe a timing issue. Here are screen shots of my setup.
Signaling Screen
Contact Screen
Channel Setup
I have tested and they show a 584.8 and 651.9. If I switch to a neighbor department of 810.2 and 584.8 it triggers.
Any suggestions on what I should try and change? Does the pretime need to be adjusted up with it being a 1 second / 3 second tone and virtually no gap?
K2NEC
5F6
Seems silly but have you checked to make sure that is the right tone pair?
cmjonesinc
I haven't used twotonedetect in years, but I did notice on the older version I used the shown detected tones were slightly off from what I knew they were. Perhaps they are off just enough to not trigger? You can record them and analyze them with audacity and see if there is any difference. Also just for kicks turn the RX pl tone off and let it be csq and see if that changes anything.
K2NEC
5F6
Yes. I use Two Tone Detect to capture the audio for other systems and that is the tone pair that it triggers on.
I don't suppose this is your department that you are affiliated to is it? Because if that's the case, chances are whoever is in charge of your radios/pagers will know what the exact pair is.
MITTYCPD
NW Indiana
Thanks for posting your screen shots. I am trying to do the same thing to an XPR7550, but in comparing your screen shots to my program I find I am missing some of the boxes shown near the bottom of the WFD Paging and the channel set up screen. Everything else looks the same. I'm wondering if maybe this radio doesn't have the paging capabilities since I'm not seeing the same info as you have shown. Thanks for your time.
KG4INW
Midlothian, VA
Make sure your CPS is in Expert View and not Basic (which is default).
MITTYCPD
NW Indiana
Thanks much. That did it. I will check my settings shortly and see what happens.
K2NEC
5F6
estone4009
Philpot, KY
I did get it to trigger today. The channel is muted until it triggers and goes into call alert. Then after the page is done it stays in call alert until you press monitor button. What could I change to get it to unmute on trigger and stay unmuted, then when monitor is pressed it would reset itself. Tying to get it so you would not miss any radio traffic with a delay of changing channel over to primary.
K2NEC
5F6
Change from call alert to selective call. Change auto reset timer to manual.
MITTYCPD
NW Indiana
Followed the information that everyone provided and it finally paged out an incident. Thanks to all who posted. It was definitely a learning experience for me. You are all the best. Thanks again.
