I didn't see where this was discussed at all but I wanted to get some input. With the 4550, or more so the TRBO line, It APPEARS that you can use the same digital contact ID more than once with different names and assign them to seperate channels of differing "systems".
IE let's say Business A uses group 1 as its talkgroup and it's labeled "BIZ A". Then you also have Business B that uses group 1 as its talkgroup and it's labeled "BIZ B".
You create to contacts with and ID of 1 and then set the correct one to each channel. WIll the radio (or should it) see these as different?
I have something similar to this setup but it appears that even though the groups are set right on each channel one of the channels seems to display the wrong group name on transmit/receive. IE the "BIZ B" channel shows a contact/group of "BIZ A". It is programmed correctly and the correct groups show for each channel.
Any ideas? Is it just as simple as you can't have duplicate contacts? I'd love to get some insight.
