XPR 4550 Interface Audio Question
70cutlass442
We are interfacing a series of XPR4550's to an IP based console setup. We have made all audio adjustments via our gateways GUI. The audio just sounds hot (audio from console mic.) I know there are input adjustments in the CPS for the external TX audio input on the back of the radio. Wondering if anyone has any tips on where to set the settings. The audio sounds "tinny" and distorted at high levels... I know I can back the audio down but looking for a sweet spot to start with.
Tech21
If you have tuner, tuner lets you adjust the audio output of the radio. The way to do it is connect the radio to a service monitor. Feed a 1000hz tone to the radio and adjust your frequency modulation in tuner until you see 1.5khz on the monitor. This requires a TIMS and a service monitor. Is the radio connected to a tone remote adapter?
Assuming you have the radio connected to a punchblock, the TIMS is connected to the TX pair and then you feed a 1000hz tone to the radio. The service monitor is connected to the antenna port. The Frequency Modulation on the Service Monitor should show 1.5Khz. It's really the only correct way to adjust the audio. Otherwise you are just playing the guessing game in tuner until the audio sound good.
N1GTL
CT
You're probably noticed but there are settings for the mic jack as well external audio. Also, make sure AGC is unchecked. I'm probably pointing out the obvious but it's easy to overlook.
What IP console are you using?
motomeso
Ontario
Remove AGC and adjust your audio in the CPS, not Tuner. I also find that using Data PTT instead of EXT PTT makes a control station sound a little better.
70cutlass442
This is interesting, not sure why the PTT mechanism matters but will give it a shot.
motomeso
Ontario
Data PTT will change the TX audio characteristic and give you all little more bottom end I find.
Project25_MASTR
Millennial Graying OBT Guy
Texas
I've never messed with their console but I have messed with their VPN gateway which is nothing more than a Mikrotik RB450G (or the current version) with the price marked up $200 over cost configured as a VPN server/client.
