Xpr 4550 warm
pyro424
Just wondering if anyone has any experience with the 4550. This is the only one I’ve owned so I’m not sure. When it’s just powered on receiving it feels slightly warm on the heat sink. Not hot just warm. Also tried turning off the back light but still slightly warm. Wondering if this is normal
pyro424
Also should add I checked the TX output with a meter and I’m getting full output power.
clbsquared
Isle of Wight County
That's what the heat sinks are for. To displace the heat build up. So naturally, they are going to be warm. If it's hot enough that you cant touch it, I would be concerned. My XPR and XTL stay on all day long and the heat sinks are always warm to the touch.
One thing you didn't mention is the environment where it is installed. Does it have ample airflow? Is it in an already heated or overly warm environment? Do you have ample size wire supplying power to it? Good ground?
pyro424
ok thanks that answers my question since you own sane radio. It’s in my house right now where it’s 70 degrees. And yes lots of airflow and good power. I checked with a ir thermometer and it’s 82 degrees. So not hot just slightly warmer than the room. I guessing it’s totally normal just wanted to hear from someone else who had one. Thanks
kayn1n32008
ØÆSØ
Sector 001
I will be installing an remote mount XPR-5550 in my car in the near future. If you keep the words right side up, the heat sink points down(????). Because of this the RF deck will be installed upside down, with the heat sink fans pointed up. Not sure why Motorola designed it this way, but it is what it is.
