XPR 5550 firmware upgrade error
CHangen702
Henderson, NV
I got a used XPR 5550 and have been trying to update the firmware but continue to get error 8862 after it reaches around 85%. I am currently on firmware version R02.00.03 codeplug 01.00.18. I have all of the upgrade firmware from R02.40.00 up to current. after googling i found one person that was able to fix the error by updating to R02.06.33 first unfortunately when I contacted Motorola they told me they no longer have that firmware avalible. Has anyone else had this issue? Any advice on how to get the firmware to update? I am using the rear port for programming and have already tried using a brand new computer with nothing but CPS installed on it. I do have CPS 16 from Motorola.
N4KVE
PALM BEACH, FLORIDA
Sometimes when an upgrade is from very early FW to the newest, it can’t be done in one shot. Many people on the Gen 1 radios with 1.00.00 wanting to go to 1.12.17 need to go to 1.06.00 first. Then from there to 1.12.17. While Moto doesn’t have the 1.06.00 any more, people may still have it on their computers. Hopefully you can find someone with the FW you need already on their computer. Good luck.
Tech21
When upgrading that way you can't just jump, you have to upgrade in steps.
CHangen702
Henderson, NV
@Tech21 yeah I know everything should be stepped up with the updates I did that with my xpr 7550s. My issue is I can’t do it that way since I can’t find the R02.06.33 firmware and Motorola doesn’t seem to have it anymore.
Tech21
That's suck and all but it's an easily avoidable problem. Do more frequent updates.
K6CV
Twain Harte, CA.
I too have the same issue with my XPR5550 going from R02.00.03 CP:01.00.18. to R02.06.05 CP:10.01.14 and have been trying to update the firmware but continue to get error 8862 after it reaches around 67%. I even tried going to R02.09.00 CP:14.00.13 with same results. What was the solution to resolve this?
CHangen702
Henderson, NV
sorry just saw your post. Yes I was able to update. I was missing the next firmware update in the sequence but once I got it I had zero issues getting it up to date. I did notice that if I did not use the rear port to update and tried to do it with the front face it would hang up on me.
brian808
I have a XPR5550 and trying to find firmware 2.09 but looking in my MOL account I don't see that version listed anymore. Can someone point me to where else I might find it?
com501
It is always helpful to check your Moto account frequently and download every version of software and CPS and archive them. Moto did that with the XTL/XTL software. You can't get the newest .10 version unless you call Moto and open a case. They REALLY want you to send your radio to the depot, every time.
CHangen702
Henderson, NV
That’s a good point, off topic but with the XTL5000 being end of life what is the current firmware version I should probably check and see what mine is running.
