XPR 5550
jep
Sicamous, B.C.
We have Motorola software and Cable for the MOTOTRBO XPR 5550 but when trying to read get three different error messages: 8395, 1687 and 1026. What do these mean and how can we correct to make the radio marketable? We bought a number of the MOTOTRBO radios and have been told by people who want to buy the entire lot that the firmware needs to be upgraded. They say there is a simple fix but are not disclosing what that might be. We have several hundred radios which were purchased with an investment was significant. We did not know we would be encountering these issues. Can anyone help?XPR2500s are another rmodel which cannot be read and provides an error code of 1089, 1064, 1046. Someone suggested the software currently programmed into these units is developmental.
riveter
MD
Sounds like USB communication issues.
Ensure your CPS is up to date and at least newer than the version last used for those radios.
Ensure you're using the right cable, OEM if possible.
Try a different computer with CPS on it.
Hope it helps.
sfd119
Did the drivers install correctly? XPRs should show up as a network device.
jep
Sicamous, B.C.
MOTOTRBO Error Messages
Drivers are installed correctly and network adapter is MOTOTRBO #3. We can read XPR4550s, XPR4350s and XPR 5350s but get error codes on the XPR2500 and XPR5550...?
